Welding to Steel Deck
Is there any concern with welding a steel angle to 18 GA deck via fillet weld (1/8")? My initial thought it no since the deck is only .0478" thick. I believe the weld will burn through compromising the strength of the deck.
RE: Welding to Steel Deck
If there is concrete to be placed in the deck then a flat plate with headed studs could be tacked to the underside of the deck.
Another question.....can the deck resist the vertical component of the brace?
Thank you all for your responses.
