NX7.5: Thicken Failure Analysis
Good morning, everyone.
I have a sheet body I tried to thicken this morning, but the thicken operation failed. I clicked the "Show failure data" button in the thicken menu, but I am unsure how to interpret the results. The information window provides the following info:
Error data: ifail = 1075 , state = 0
Thickening failure
Minimum radius value = 16.85000000000
was found at 1 point located at coneheads with solid font
Minimum radius value = 0.32500000000
was found at 1 point located at coneheads with dotted font
I have attached a screen-shot for reference. What I'm wondering is if anyone can tell me how to interpret thicken failure results in general.
Thanks!
Thickening failure
Thanks!
RE: NX7.5: Thicken Failure Analysis
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I needed to thicken the part to 0.100". It will thicken up to some fraction of that (I think it was .085 or .095"), but it won't thicken to what I need. I found that by removing the offending blends from the sheet body, I could thicken the part, then apply the blends to the solid body that resulted.
Thanks!
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Consider a "U"- shape. trying to thicken the "U" outwards will accept any value but inwards only some value before the offset face intersects itself.
Applying thicken on a "S" shape will have problems in both directions at a certain value, it has curvature in both directions.
On your model, the highlighted face has curvature in both directions. Probably due to the surrounding faces.
( Reading your post , the value presented should accept an offset of 0.1, the min radius noted is 0.325. Strange.)
Tomas
www.nxjournaling.com
