calculating contact pressure between a sphere and a cylindrical sleeve
Hello everybody,
I need to design a joint consisting of a steel ball stud able to slide and spin in a plastic sleeve bearing with the same diameter. How does one approximately calculate the contact pressure between the ball and the sleeve? The only examples I found are for the contact between two spheres or two cylinders.
Thank You in advance.
RE: calculating contact pressure between a sphere and a cylindrical sleeve
Second question. According to what I read, the contact pressure can easily exceed the yield strenght of the material and that the max safe contact stress is determinet via experiment. Is there a way to roughly approximate the max safe contact stress?
In your case, the plastic sleeve is likely to be the one taking the bulk of the deflection, and will likely fail first.
How do you think will the murtfeld plastic (yield strenght 76 MPa) handle the 144,3 MPa of contact pressure? I will inform you of the results once the prototype of our machine is tested. Can anybody recomend me some easy literature on this matter?
