can we use copper pipe for chilled water system?
Hi All,
We are doing air conditioning for ships and as per owner spec, the piping should be copper piping. Is it possible or allowable to use copper pipe. If its yes please let me know the advantages and disadvantages of using it.
Giri
Giri
RE: can we use copper pipe for chilled water system?
The answer is yes you can, the only difference if the pressure drop
Giri
Not having experience with HVAC installations on ship either, hopefully someone with ship experience can weigh in on this factor.
http://www.copper.org/applications/marine/
