How to hide silhouette curve
I believe there must be a simple solution but I don't find it. Problem please see attached screen shot.
The dash line circle is from a thread hole at far end of the part. It is a silhouette curve. I don't want it to show in this section view. If I select it and hide it, many other lines and curves are hidden as well. I tried also turning off the Silhouettes in View Style, but it did not work. How do I get rid of this dash line circle only?
TIA
TIA
RE: How to hide silhouette curve
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
But why does it happen? Why do some threaded holes not have these curves and some have?
