Limiting temperature for carbon steel API 5L and ASTM A694 F65
Hi All,
Can I have limitng temperatures (max/min) for carbon steel (eg pipe API 5L and forging ASTM A 694 F65)?
Will the above materials are suitable for temperature -80 deg C
RE: Limiting temperature for carbon steel API 5L and ASTM A694 F65
What code are you designing to?
Look there for the answer.
Design Code is DNV-OS-F101 / PD 5500.
