To save listed results in a file
Hi, I am a newbie to ANSYS. I am trying to write a loop to run different loads to my model and then save the results for analysis. However, I could not find the command to save the listed nodal results. Please help me. if you know how to do it.
Thank you very much!
RE: To save listed results in a file
Hi!
You can use the /OUTPUT-command to redirect any text output to a file. Any result listing you perform after redirecting the output will be directed to a file.
/PB
