Constrain New sketch to existing sketch
Is there anyone who can tell me which customer default I need to change in Nx8.5 so that I can begin a new sketch, but constrain to an existing sketch? For a simple example: I have a square plate with a slot in it as my first sketch. I extrude a .5" thick solid from the sketch. I wish to now create a new sketch which will be a circle or "starter hole" for CNC programming purposes and constrain it to my slot sketch. I know I have been able to do this with Nx4.0 and I think Nx7.5. When I try this in Nx8.5 It will not pick up the existing slot sketch as something to constrain to.
Any help in this matter would be greatly appreciated. Thanks in advance...
RE: Constrain New sketch to existing sketch
Also make sure that the pull-down shown in the attached picture is not set to Active Sketch Only
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
