Material for Aircraft
For aircraft please name some good (High Specific strength, cost efficient) material for Beams that will undergo both compression and bending.
Its like homebuild aircraft of about 10 ft in length and 50 kg in mass.
RE: Material for Aircraft
for homebuilds you want to use the cheapest, most available material. there's little advantage to using high strength materials (even 7075) because of cost.
PVC might work in your case if it readily available, and if you can characterise it (strength, bearing, ...)
would you PVC beam be a single piece (pre-molded) ? commercial available ?
if a built-up beam, how would you join the pieces together ?
do you plan to test this ? or just analyze it ??
Wood is simple to work, has excellent strength to weight properties, and easy to inspect and repair. Using the proper adhesive is important when using wood. For certified aircraft, the only approved adhesive is Resorcinol. Classic does have an approval for an epoxy adhesive, but there is a memo from FAA Aircraft Certification Services to DERs instructing us to not approve any repair or alterations using epoxy. I know a lot of homebuilders use adhesives like T88, but don't use it on certified aircraft.
Wood - The original Composite!
Thanks everyone
