Macros vs. Journal in NX8.5
Hello All,
I was searching for an existing forum on this topic, with little success. Therefore I would ask this question.
I am creating a series of macros to simpify things like changing the format size of a drawing (including the imported border), adding part attributes to models and drawings etc... My question is really more along the lines of using a Journal over a Macro. Can anyone shed some light on which one is better or more editable?
Thanks in advance for any advice.
Richard Andrew
Aerojet Rocketdyne
Richard Andrew
Aerojet Rocketdyne
RE: Macros vs. Journal in NX8.5
Journals will allow more flexibility, easier to edit and should work with future versions.
VBA or UGopen C/C++ code can also do what you need, but may be more complex in their programming requirements.
Ben Loosli
www.nxjournaling.com
Richard Andrew
Toolbar File (.tbr)
BUTTON <B1>
LABEL <Label>
ACTION <Path to journal file>
Menuscript File (.men)
BUTTON <B1>
Just replace what's in the <> with whatever you need and do not include the <> in your file.
Daniel Sikes
Design Engineer
Young Touchstone
NX 8.0.3.4
Thanks for pointing me in the right direction. I am thinking of converting my old user tools to updated menus. Attached is a picture of my current setup. I am assuming I need to create a new .men file that then points to several toolbar options. Any advise on structure is appreciated from anyone.
Richard
Daniel Sikes
Design Engineer
Young Touchstone
NX 8.0.3.4
In the Siemens community, there is forum for customization like this, where you should get some good feedback.
http://community.plm.automation.siemens.com/t5/NX-Customization-and-Programming/ct-p/NXProgramming
If you are on NX9 or newer, it might be time to switch over to a custom ribbon or border bar.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Thanks to everyone who provided input to the thread. I have modified our user tools and am migrating away from .UTD files to Toolbars and Menus. Attached is a shout of what I did for us here. Thanks Again for your direction.
Richard
