NX 9 importe stl disappear
i'm having a problem. I imported the .stl in nx and i've been working some time with it normally and then suddenly dissapered. Only frames are visible(see photo).
Maybe is it something that i pressed, or i don't know. I've tried to hied unhide. Doesn't work.
Thanks a lot
RE: NX 9 importe stl disappear
hi
i am new in this forum website, and i am not sure how to find your photo.
my tips is go to View -> Camera -> Edit...
so i hop you get back your hol modell.
If there is a faceted body in the partfile, You can verify it's existence by "Information - Other - Layer".
You should then be able to read something similar to :
Total Hidden Categories this
Layer Status Objects Objects Layer is Included in
1 Work 63 57 ALL
24 Line 22 Arc 2 Solid or Sheet Body 4 Sketch 1 Lightweight Body 4 Datum Axis 6 Datum Plane
The boxes i see in the image does not to me look like outlines of facet bodies, rather assembly-component previews.
Tomas
