Runtime error
Runtime error
Runtime error
Hi all. I have tried for quite a while to figure out what is wrong with this code.
I've attached an image of the code and the error. It has to do with the vlookup portion of the code.
I want a message box that shows the notes determined by the vlookup.
I think it has something to do with the way I've set up the offset. Not sure
Any advice?
Doug
RE: Runtime error
I agree with IRstuff.
Could passing the Target cell ByVal be the problem?
Which line does the error message occur on?
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
RE: Runtime error
Sorry Guys. Here is the code.
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
Dim isect As Range
Set isect = Intersect(Target, Range("D:D"))
Dim a1 As Range
Dim targetoffset As String
Dim notes As String
Set a1 = Range("a1:a1")
targetoffset = Target.Offset(0, -2).Value
notes = Application.VLookup(targetoffset, Sheet1.Range("B5:Q11"), 16, False)
If Not isect Is Nothing Then
a1 = targetoffset
MsgBox "Notes: " & notes
End If
Cancel = True
RE: Runtime error
IRstuff, the code is called by d double click in column "D".
Doug, the error code is related to the notes=......vlookup.
Doug
RE: Runtime error
4thorns,
Two suggestions:
1. Declare targetoffset as Variant
2. try application.worksheetfunction.vlookup instead of application.vlookup
yakov
RE: Runtime error
Yakov. It looks like your suggestions made the difference. It seems to be working fine now.
I'm sure I will have to make changes to it as the spreadsheet progresses but it's a good start.
It may not be the prettiest code but with the limited time I have to work on it it'll suffice for now.
Dim isect As Range
Dim G2 As Range
Dim targetoffset As Variant
Dim notes As String
Set G2 = Range("G2:G2")
On Error Resume Next
notes = Application.WorksheetFunction.VLookup(targetoffset, Sheet2.Range("B5:Q11"), 16, False)
G2 = notes
End If
Cancel = True
End Sub
Thanks again everyone for your replies.
Doug
RE: Runtime error
Glad it helped!
