Korboggen Head
Korboggen Head
Dear All,
Does anyone know what is korboggen head,
and where can i find specification for this in ASME section VIII or any other section,
RE: Korboggen Head
https://www.google.com/search?q=korbbogen+head&...
and this:
http://en.wikipedia.org/wiki/Head_%28vessel%29
and this:
http://www.fondeyur.com/korboggen-heads.aspx
and there is more.
Sometimes its possible to do all the right things and still get bad results
RE: Korboggen Head
Klopper Heads are torispherical heads with crown radius equal to OD of the skirt and knuckle radius equal to 10% of OD of the skirt.
Korboggen heads are more close to semi ellipsoidal with crown radius of 80% of skirt OD and knuckle radius of 0.154 x OD.
Considering the above dimensions, these heads can be designed for Section VIII Div 1 using torispherical head formulae.
RE: Korboggen Head
RE: Korboggen Head
you guys gave me much more clear picture..
RE: Korboggen Head
Klopper and Korboggen heads are used in pressure vessels
Based on their shape and radius, klopper is used in steel tanks and korboggen ends are more commonly used in GRP tanks due to the fact that the stresses (because of the internal pressure) are less in korboggen ends. klopper shapes in plastic are not recommened for pressure vessel tanks
gorostidi
