6 inch flanged body valve radiography with ir-192
What's the best SDF and source angle to make a radiography of the drilled holes flange of 6 inch body flanged valve
with ir-192 with the minimum image distortion of the holes.
Thanks so much the answer will be a great help.
Kamal62
Kamal62
RE: 6 inch flanged body valve radiography with ir-192
The most important information you haven't given us is what you are actually looking for ?
DD
