How to get end plate thickness in this case?
I've this end plate with two bolts around each flange , I hope you can give me a method to get this end plate thickness under axial and shear force as illustrated.
RE: How to get end plate thickness in this case?
I didn't see any forces on your drawing ?
Is this a footplate, an endplate, a splice?
I'd assume a standard 45 degree load spread back to a line at the flange tips perpendicular to the flanges and then check flexure there. It's a difficult situation. Strictly speaking, this method isn't as applicable in this situation as it is when the load spread terminates at a stiffening element parallel with the assumed axis of plate bending.
