Axis pattern not working correctly.
I have little experiencie with proE but I have experience in solidedge, NX and solidworks. so the proE logics sometimes escape my mind.
What i want to do:
Results:
Im using ProE wildfire 5.
see attached files with various combinations resulting in failure.
What i want to do:
Place 4 "L" brackets in the external face of the round part.
What i did:I created a round feature of a sketch to create the first bracket. axis on the center of the round part.
After that i tried to create an Axis pattern to place the remaining 3 brackets
Results:
Depending on the method prefered i obtained no result, failed geometry and also offset brackets in the vertical axis.
RE: Axis pattern not working correctly.
in one of the files the sketch is not dimensioned, but in the other files sketches are fully constrained.
is there any reason for the offset on the features that did worked?
Thanks a lot ;)
To fix it, try this:
-delete the pattern (only the pattern) so that 'Revolve 2' is no longer being patterned.
-in the Model Tree, right click on 'Revolve 2' and select 'Edit Definition'.
-from the Ribbon, select 'Placement', which brings up a menu showing the 'Sketch 6' is the source for the sketch.
-click on 'Unlink', which essentially copies 'Sketch 6' into the revolve feature and breaks the link between them.
-re-create your pattern. When I did this, it was fine.
I did what you described, i keep having the same offset issue. (only in the files i attached here).
i did "save as" in another file and recreated those features again(before sketch 6) and everything worked fine, even without unlinking the sketch.
Also "copy>paste special>translate" also worked fine.
