Spring Constant for Slurry Wall Design
Anyone have any thoughts on reasonable approach for spring constant for slurry wall design (to support structure vertical loads)?
RE: Spring Constant for Slurry Wall Design
Do you need spring stiffness (dimensions: force/lenght) or the coefficient of subgrade reaction (dimensions: force/lenght^3)?
What are width, lenght and depth of the slurry wall(s)? Elastic and Shear moduli of soil? Any results of load tests?
I'm interested since I never came across such a problem. I would do just as above first and judge if the result is reasonable.
www.mccoy.it
I'll ruminate about it, if there is no simple solution I'm afraid you'll have to do it rigorousluy by the definition: K = W/s where W is the load in units of force, s the settlement in units of lenght. In lieu of load tests the settlements must be calculated by the elastic theory or FEM methods.
www.mccoy.it
