Tool or workflow similar to Wave Geometry in NX
is there similar functionality in SW2013 as in NX that allows the linking of individual surfaces or entire solid bodies from other parts in an assembly?
RE: Tool or workflow similar to Wave Geometry in NX
Chris, CSWA
SolidWorks 14
SolidWorks Legion
hope that helps,
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesGryphon Environmental
www.2gryphon.com
www.scottjbaugh.com
The purpose is to have a high level design intent and curvature (using industrial design concept) that drives the whole assembly.
I built a complete water spray house (a large machine that cleans parts on a conveyor system) and it was controlled by 3 dimensions and about 4 options and the entire assembly updated along with all the parts (about 1000 components)and the drawings as well. So what took months in AutoCAD took only a short time to update the assembly and components and about an hour to update drawings, which was just minor clean up and adjustment.
Scott Baugh, CSWP
www.2gryphon.com
www.scottjbaugh.com
