ETABS VBA Programming (Help with SetLoads Function)
I'm trying to create a series of linear modal time history load cases in ETABS using VBA and the ETABS OAPI. However, when I try to set the "Applied Loads", it doesn't seem to be changing anything when I go to check the load case after the code has run. Here's the applicable portion of my code:
CODE -->
Dim LoadType(0) As String
Dim LoadName(0) As String     'Load pattern name
Dim Func(0) As String    'Forcing function
Dim sf(0) As Double    'Scale factor
Dim TF(0) As Double    'Time factor
Dim at(0) As Double    'Arrival time
Dim CSys(0) As String     'Coordinate system
Dim Ang(0) As Double    'Angle
LoadType(0) = "Load Pattern"
LoadName(0) = "Step1"
Func(0) = "Func1"
sf(0) = 1
TF(0) = 1
at(0) = 0
CSys(0) = "Global"
Ang(0) = 0
ret = SapModel.LoadCases.ModHistLinear.SetLoads("StepCase1", 1, LoadType(), LoadName(), Func(), sf(), TF(), at(), CSys(), Ang())
The other annoying thing is if I use the .GetLoads method, it doesn't return anything either. Can anyone point out what I'm doing wrong?
