text in drawing to part
RE: text in drawing to part
With the dwg file active in CATIA and an already opened CATPart (the code bellow is a quick and dirty mix of a recorded macro and some other old code).
CODE --> CATScript
Language="VBSCRIPT"
Sub CATMain()
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = drawingDocument1.Selection
selection1.Clear
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.Item("Model")
selection1.Search "Name=*Main' 'View*,all"
selection1.Copy
Rem---------------------------
Rem User selection of the CATIA window
Dim Windows1 As Windows
Dim SpecsAndGeomWindow1 As Window
Dim sArray As Array
Set Windows1 = Catia.Windows
DUMMY = ""
ii = 1
For i = 1 To Windows1.count
	WindowName = Windows1.Item( i ).Name
        	DUMMY = DUMMY & ii & ".)  " & WindowName & Chrw( 10 )
        	ii = ii + 1
Next
DUMMY = "Enter your Number, for example 1 or 2 " & Chrw( 10 )  & Chrw( 10 )& DUMMY & Chrw( 10 ) & Chrw( 10 )
USERCHOICE = InputBox( DUMMY, "Enter Number of Window which will be activated:" )
If USERCHOICE = "" Then
Exit Sub
End If
If IsNumeric( USERCHOICE ) Then
        iSelect = CInt(USERCHOICE)
        WindowName = Windows1.Item(iSelect).Name
        Windows1.Item(iSelect).Activate
End If
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim selection2 As Selection
Set selection2 = partDocument1.Selection
selection2.Clear
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
selection2.Add body1
selection2.Paste
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
thanx. i did some changes to macro and it works very well. i liked choosing windows where to put dxf/dwg. is there any way to set catia to export/import dxf files with mostly arcs and lines?
