hide object and drawing
on assemblies i use scenes for combining objects i want to see on a drawing. it doesn't affect a drawing if i exit from scene and playing
with hide/show. drawing don't asks me for an update.
how to deal with multiply bodies? when i hide some body, drawing asks for update and as a result a body is hidden in a drawing.
is there a way to prevent drawing from doing this even if i hide a part in a tree? i don't want hiding objects to affect a drawing.
RE: hide object and drawing
if your view is from a single part: use the object view\modify links option to have your view link with only the bodies you want.
Eric N.
surpriseFernando - NEVER lock views! (CATIA rule #3)
Well jackk, this depend on companies rules/procedures/methods smile ....I remembered that because it is one of the rules in AIRBUS...searching with Google I found this ...when I will found exactly the number of the AP (Airbus Procedure) or AM (Airbus Methods) I will mention here.
Anyway, if I remember correctly, even Q-Checker customized for Airbus, will not allow you to check-in in VPM if the views are not locked...
Catia V5 Guidelines - Scribd
https://www.scribd.com/doc/22754420/Catia-V5-Guide...
Nov 19, 2009 - 4All Drawings should be created with the Airbus Title Block Application. 4Picture ... 4All views should be locked prior to filing or vaulting. ... from a front view which is scaled down, moved off the drawing sheet, and hidden. ... 4The only exception to this rule is drawings that include reference geometry, which...
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
