Dust collector for energy recuperator cleaning
I have a very particular project to adress.
My client has energy recuperators, which are basically big drums with coils inside that are used to gather exhaust energy from engine exhaust in a closed hot water system.
We are looking at ways to collect the sooth that comes out when cleaning these recuperators.
The annual cleaning is made manually with a guy going inside with compressed air blowing away the sooth.
Actually the chimney pulls the dust out but the factory wants to collect it instead.
The problem i have is to find a mobile dust collector, maximum height of 84'', that could pull around 5000 CFM at 7'' H2O.
So far i have not found a manufacturer that could supply a unit for such an application, hope you guys can give me a hand!
Thanks all.
Thanks all.
RE: Dust collector for energy recuperator cleaning
You can rent equipment of the type Chicopee mentions . The recovery systems used for alternate media blasting may work better for your purpose. De long equipment company in Atlanta Ga. and Greenville Sc. is one source.
I have included a link to one maker just for illustration.
B.E.
You are judged not by what you know, but by what you can do.
