Autocad 2012 - change overwritten font in multiple mleaders
Hi all,
So I have a bunch of multileaders (50) which have a text style that uses simplex font. However, they have all been overwritten in the "in place mtext editor" to arial font. I'm determined to find a way to change them back to simplex all at once, but can't find anything. If this isn't possible, a way I could change each individual one in approx. 1 click would also be useful. You can't change one and then match properties with the others, but that would be an example of the second type of solution. I've run into this problem before, and any help other than "don't overwrite in the in place editor" and "change each one in the in place editor individually" would be greatly appreciated. But if you all think these are the only available options, I can change each one individually. I just feel like there has got to be a better way. I've attached a file with the multileaders, and am using Autocad 2012.
Thanks so much in advance,
labeattie
http://files.engineering.com/getfile.aspx?folder=d...
labeattie
RE: Autocad 2012 - change overwritten font in multiple mleaders
After doing that, you could globally change text style using usual procedures.
https://cadabyss.wordpress.com/2010/01/04/stripmte...
