Is it Possible to Anchor Views in NX9
Not sure if Anchoring Views is the correct term. We have details that need to be made in a specific location and position according to body parts of automobiles. We have always had to create each of these fresh.
What I would like to do (if possible) is model an object and do the drafting (in the same file) and then in modelling I want to be able to ove that solid model around, flip it around to where ever I need it and the views on drafting will stay where they are and update and continue to show the same view of the solid model.
This would allow us to create a standard detail and have most of the drafting set ahead of time. So the modeller would just do a save as, bring it into his assembly, position the solid model (not the component) to where he wants it and only have to adjust and add a little bit of drafting.
Is it possible to anchor a drafting view to a solid body?
RE: Is it Possible to Anchor Views in NX9
First move whichever solid you'd like to draft to it's own layer.
You can set your WCS up to this solid or to the body parts its connected, set your view to your WCS, then save your view. Then in drafting, place the view you'd like, click Format > Layers Visible in View and turn only the layer with the solid on it to visible, and the rest invisible.
Lets say I have a simple "L" shaped block. I can go to the drafting side of NX and add drafting views and title block and dimension it up. Now, if I was to go into modelling again and move the body over 500mm and turn it 20 degrees, when I go back to drafting, the view will be all messed up. It may be blank as the solid moved out of the area, and if I update it, the view would show the same L-block but at a funky 20 degree angle.
What I am wondering if it is possible, is to anchor the drafting view to the solid body, so that in modelling I could move that solid anywhere and in any position I want, and when I go back to the drafting side, it still shows a good side view of that L-block. So in a sense, the drafting view will adjust to always look at the same perspective of the solid body.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
If so, the general rule is that do not move the solid body in it's original file.
Create a drawing in a separate file ( or the master file.)
MOVE the model in an assembly, then it will only move in that assembly and all above assemblies.
This way you can place the same detail in multiple positions and orientations in the assembly.
Tomas
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
This is why I had the hope of drafting views that would adjust to the model being moved. Then we could have one done up and just do save as to it each time we need it. Bring it into the assembly at absolute and move the model to the correct position. And the drafting will still be good.
www.nxjournaling.com
I have another question on this. I know this will probably really be pushing my luck, ad I dont know if you even have access to the hole chart we use for GM work, but if anyone knows if it is possible to use the hole chart with associated views, it would be awesome. As it stands, the views update great, but the X, Y, Z Datums get messed up. I was hoping they would just update the letters. lol Also body balloons dont work so well either.
