Torsion differential equation
hey everyone,
i have a channel beam under a linearly varying torsional moment
my question is:
given the torsion differential equation written as:
phi''[x] - [E*Jw/(G*Jt)]phi''''[x] = -[mx/(G*Jt)]
how must it be written for a load like the one in the attached figure?
in other words, what "mx" should i use? or should i divide the beam in half? i've tried several things but the solutions came out "suspicious" every time.
my question is:
RE: Torsion differential equation
Why?
the case i'm studying is torsionally fixed at both ends (phi = 0) and in two separate scenarios it can be warping fixed (phi' = 0) and warping free (phi'' = 0)
i've tried to divide it in half considering phi(0)=phi'(0)=0 and phi'(L/2)=0 but the results were not good
Be careful with torsional fixity. It requires rotation restraint and warping restraint. Regardless of your boundary condition at the real supports, torsional fixity can be assumed at L/2 in a half span model.
But that's just something that quickly popped into my head, I'm no solid mechanics expert.
That is, unless this is a existing member that you are trying to make work/pass under a new load.
it'd react the same way if if were a constant moment (ie zero-some-zero twist) ... the amount of twist is likely to be higher for the tapering torque.
I divided the beam in half and at L/2 applied warping fixity (but free rotation) so now i just have 3 boundary conditions
for the left part:
phi'[x] - [E*Jw/(G*Jt)]phi'''[x] = Tm (2 (1 - b) x/L + b)/(G*Jt), phi[0] = 0, phi'[0] = 0, phi'[L/2] = 0
and for the right part:
phi'[x] - [E*Jw/(G*Jt)]phi'''[x] = -Tm (2 (1 - b) (L - x)/L + b)/(G*Jt), phi[L] = 0, phi'[L] = 0, phi'[L/2] = 0
where b is T0/Tm.
The results now seem plausible but i don't know for sure if they are correct
what do you guys think about this?
it is a very easy way to accommodate difficult functions. I'm not sure how it shakes out for torsional functions, but for beam functions it works quite well.
