Soldier Pile Walls Walers Requirement
What are the requirements/regulations for the walers in soldier pile walls? Specifically I'm interested in the vertical distance between walers requirements. Wood lagging is used for these walls.
RE: Soldier Pile Walls Walers Requirement
Depends on the lateral deflection you can tolerate without being sued by your neighbor considering all the structural design parameters used to design the shoring system.
Mike McCann, PE, SE (WA)
