Wireframe colour
Wireframe colour
Wireframe colour
This might seems a silly question but I cant change my wireframe colour how do I do this
Thank you Daniel lamb
RE: Wireframe colour
What version of NX are you on?
Edit -> Object Display
nx9
By "wireframe" do you mean:
  1. you have solid/sheet bodies, and have switched to a wireframe rendering mode and want to change the color of the body edges
  2. you have created a network of curves (sometimes referred to as "wires") and want to change their color
  3. you have solid/sheet bodies in a shaded rendering mode and want to change the color of their edges
  4. none of the above
For case 1, the edges will take on the body color, which can be changed through Edit -> object display (as noted by jerry1423).
For case 2, if the curves are part of a sketch they will default to the sketch color preferences, though there is an option to turn this off and display them as a user specified color instead. This can be found in Preferences -> sketch -> sketch settings -> display object color (note that if you turn this option on, you will lose the color coding of the sketch status: red for overconstrained, green for fully constrained, tan for reference curves, etc). If they are not part of a sketch, you can change their colors using Edit -> object display.
For case 3, you can change the edge color used in the "shaded with edges" rendering mode by going to Preferences -> Visualization -> visual -> general display settings -> shaded edge color.
For case 4, more explanation will be needed.
www.nxjournaling.com
