Property data for 2004 Aluminum alloy?
Howdy all,
I am looking at finding a substitute for 2004-F or 2004-T62 Aluminum alloy. This alloy is used for super plastic forming. Since it is a specialty item there are no published material properties that I could find. Does anyone have material data for me to evaluate alternate materials to use as a substitute? We will be using a different forming process.
-Kirby
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Property data for 2004 Aluminum alloy?
http://www.alueurope.eu/talat/lectures/3804.pdf
Since this is a high strength alloy, and I'm assuming you need something in sheet kinds of thickness (not a forging, not screw machined from bar, etc.), I would start with 2024-T81. If stress corrosion cracking is a concern, you may want to investigate other alloys like 2124, 7050, 7475, etc.
https://www.alcoa.com/mill_products/catalog/pdf/al...
http://www.kaiseraluminum.com/customers/products/p...
The material is covered by AMS4208 (for bare) and AMS4209 (for alclad). Would this spec have the minimum values? That would give my substantiation a better grounding.
-Kirby
Kirby Wilkerson
-Kirby
Kirby Wilkerson
