ASME Nameplate
ASME Nameplate
ASME Nameplate
In regards to an ASME pressure vessel nameplate with a NB registration number, is the ASME / NB marking REQUIRED to be made with the stamp or can it be engraved on the plate? I am required to use 316L on these nameplates and the thinnest material they can use is 20ga. The stamps will not leave a legible indication on the nameplate due to the hardness of the material. ?????
RE: ASME Nameplate
The ASME certification mark and the National Board mark must be stamped on the nameplate with the stamps that are provided to the company doing the work.
RE: ASME Nameplate
Here is what Section VIII, Div 1 Code states
(c) Nameplates may have markings produced by either
casting, etching, embossing, debossing, stamping, or engraving,
except that the Certification Mark shall be
stamped on the nameplate.
RE: ASME Nameplate
Thank you!
RE: ASME Nameplate
Just use a press to stamp your NBIC R certification stamp or ASME U certification stamp into the nameplate material. I've used same to stamp 2205 duplex stainless.
