SecVIII UG37 h:nozzle projects beyond inner surface of vessel wall
ASME Sec VIII, UG37(a) Defines
"h" is distance nozzle projects beyond the inner surface of the vessel wall.
when we insert plain cut-end pipe to cylindirical shell,
is "h", the length measured from center axis of pipe,
or
is "h", the minimum length measured at the edge of pipe?
or
RE: SecVIII UG37 h:nozzle projects beyond inner surface of vessel wall
“h” is the minimum length !
Please look at Fig. UG-37.1 - it indicates: “use smallest value”.
You can also see it from that the section in this figure is in axial direction.
Regards.
