Piling Options in Permafrost
What are attractive/unattractive piling options in permafrost? Can screw piles be installed? Driven steel? Drilled concrete piers? CFA?
This is a total rookie question but, here we go: is the piling design method to rely on competent soil below the frost depth? Or do you actually rely on the permafrost soil itself for resistance? I suppose one has no choice but to rely on the permafrost for lateral load resistance.
Anybody know of a good article covering permafrost pilings?
If anyone wants more context, please refer to this thread: Link
RE: Piling Options in Permafrost
Here's what I have to say about buildings. . . The greatest risk is the conditioned air thawing the permafrost to depth. It may take a few decades, but beware! The use of piles allows for the first floor of the structure to be elevated and the cold winter air to keep the flux of coldness from such long-term thawing. If you don't have conditined air, then this may not be relavent.
We used pile foundations for structures. The piles were rough cut and installed in holes drilled using a highway auger. They'd often go to 15 or 20 ft and it'd be frozen for the full depth. We'd keep the cuttings from the hole, mix them with water and use the slurry for pile backfill. We'd install thermisters to the pile to look at temperature as a gauge of ice development and setup. We'd often take samples of the slurry and measure the freezing point to make sure salinity was not affecting the freezing poing.
Got to be careful about load-bearing slabs. They can be designed, but require insuation layers and gravel. (Graven is often hard to find and expensive in the permafrost.) Water tanks are very problematic as the heat sink of all that water wants to thaw the permafrost. Cryoanchors are thus needed below many ground supported structures.
I can't provide design details, as I've been out of the business for too many decades. Just sharing a bit of my former experience.
Good luck and dress warm!
f-d
ípapß gordo ainÆt no madre flaca!
I'm assuming by his rough cut description of the piles they were timber (as noted by someone in the other thread). I have seen steel pipe piles used in northern work however I haven't done any design myself.
a couple of feet (maybe 3) would be sufficient for air space.
f-d
http://www.brooks-alaska.com/kotzebue/documents/fi...
In Kotzebue city, shallow souils are primarily silt and organic silt.
Auger freeze-back pile are often used in this material. There is a concern of warming permafrost in the region; this can be mitigated with deeper piles, or if heavy loaded & critical structure, use of thermosyphons.
Driven steel piles (vibratory) have been more commonly used in permafrost area recently, dpending on soils and capacity. Pre-drilling a pilot hole is typically required.
