How can I convert SCFH (gas phase) to bbI/day .
Everyone,
I need your help to convert SCFH (gas phase ) to bbI/day , I'm currently doing a volume balance around a distillation tower and need to covert that amount of the off gas (SCFH)to bbI/day ??
RE: How can I convert SCFH (gas phase) to bbI/day .
You are going to have to find and review your material balance around your column. Assume that this balance is the normal operating condition. Calculate your gas rate and liquid production rate and develop a "rule of thumb" ratio of gas to liquid flow rates.
Actual operating conditions, feedstocks, etc will effect this ratio. Thus it cannot be used for completely accurate production analyses.
Good luck.
Trying to convert SCF to bbl assumes a pressure and temperature of the bucket you are trying to use. Just don't.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. ùGalileo Galilei, Italian Physicist
