Gravel/sand pressure?
The simplest way to present this question is to assume the following:
Typical formwork.....6in wide by 7ft tall and filled with gravel.
What is the design pressure from the gravel?.....thanks in advance for your response.
RE: Gravel/sand pressure?
http://www.slideruleera.net/Steel-Piling.html
www.SlideRuleEra.net
www.VacuumTubeEra.net
