CATOUT QUESTIONS
CATOUT QUESTIONS
CATOUT QUESTIONS
I'm working on a Declaration script for a PDF plotter setting. I have it set fairly well i think but the %CATPRT_DOC_SHEET_NUM% and %CATPRT_DOC_SHEET_COUNT% do not return any thing.
CODE -->
set CATOUT=%CATPRT_DOC_PATH%\%CATPRT_DOC_NAME%_Sheet%CATPRT_DOC_SHEET_NUM%_of_%CATPRT_DOC_SHEET_COUNT%.pdf
so it sould print
CODE -->
\\netpath\test.CATDrawing_Sheet1_of_5.pdf
but instead i get
CODE -->
\\netpath\test.CATDrawing_Sheet_of_.pdf
Any suggestion?
The full scrip is below:
CODE -->
rem Default: %CATPRT_DOC_PATH%\%CATPRT_DOC_NAME%_Sheet-%CATPRT_DOC_SHEET_NAME%_of_%CATPRT_DOC_SHEET_COUNT%%CATPRT_PRINTER_NAME%
if %CATPRT_DOC_SHEETS_COUNT%==1  goto OneSheet
    set CATOUT=%CATPRT_DOC_PATH%\%CATPRT_DOC_NAME%_Sheet-%CATPRT_DOC_SHEET_NAME%_of_%CATPRT_DOC_SHEET_COUNT%%CATPRT_PRINTER_NAME%
    goto End
:OneSheet
    set CATOUT=%CATPRT_DOC_PATH%\%CATPRT_DOC_NAME%%CATPRT_PRINTER_NAME%
:End
RE: CATOUT QUESTIONS
just wanted to bump this up while every one is active... I'm really hoping it's an easy fix and i'm just missing some thing...
