catia pdf issue
catia pdf issue
save as pdf works fine except one thing. i can't change any setting like line thickness.sometimes hidden lines looks solid especially on small elements like countersinks. if i use print as pdf everything is fine except text. is not recognizable by adobe pdf.
is there any way to change setting in save as pdf? did some searches on board and nothing helpful.
RE: catia pdf issue
go to the printers properties window
next to the driver drop down there is the "Advanced Configuration.." button. click it
in that window
-uncheck "save as Pdf/a
-uncheck "Discretize fonts"
-check Always subset
click ok
try your print again and you should be able to hylight the text
RE: catia pdf issue
RE: catia pdf issue
i use adobe pdf printer. i like to use safe as pdf more than print. i use macro for that.
i will try your settings tomorrow.
RE: catia pdf issue
good luck
