Short circuit asymmetrical factor
Do I need to consider the calculated short circuit asymmetrical factor in case of arc fault in a MV system?
For bolted faults I already need to provide a zero crossing delay for safe breaker opening.
Thanks.
Thanks.
RE: Short circuit asymmetrical factor
Arcing fault have a lot of resistance (the arc), so the X/R ratio is generally low. This results in low dc offset current.
But no one can really answer your question without more information.
match the correct interrupting capacity of the breaker in case of bolted fault. The confirmation of lower X/R ratio (that implies low asymetrical factor) in case of arc fault by IEEE would permit a fast detection and a faster breaker actuation.
Am I correct?
