calculation thermal analysis PWHT
Hi
can we calculate thermal analysis on material when PWHT or after PWHT.
please inform reference for calculate
KRN
RE: calculation thermal analysis PWHT
First, what is your idea of a thermal analysis?
Why is a thermal analysis needed?
Time and thickness requirements for heating, PWHT and cooling are defined in most codes and standards for materials.
thank you for your replied
based on owner request but they not give requirement, rule, reference code.
Why is a thermal analysis needed? we need thermal analysis due to identify/confirm the Weld metal, HAZ properly heated during local PWHT/PWHT.
normally, only chat PWHT, and hardness. but owner request for calculate thermal analysis.
the material as below:
PWHT is SA516-70,
thickness 13mm
holding time: 60 minutes
colling method by atmosphere,
method PWHT as per ASME Sect VIII. Div.1 2013ed
In this case, what I would recommend is an engineering review of the PWHT parameters to be provided to your client;
Typically, for P-No 1 base material, PWHT is not required unless forming strains have been performed or it is required by the client, if using ASME Boiler and Pressure Vessel Code, Section VIII, Div 1. If using ASME B&PV Code, Section VIII, Div 1, Table UCS-56, the PWHT temperature range for P-No 1 base material is 595 deg C or 1100 deg F minimum.
The PWHT hold time is also in Table UCS-56 and stated as 25mm thickness/1 hour or 1" thickness/1 hr. So, for a plate 13mm in thickness, if PWHT is required by your client, the minimum hold time at 595 deg C or 1100 deg F and would be 30 minutes at PWHT temperature.
The heating and cooling rates shall be based on the following requirements in UCS-56 below;
UCS-56
(2) Above 800°F (425°C), the rate of heating shall
be not more than 400°F/hr (222°C/h) divided by the maximum
metal thickness of the shell or head plate in inches,
but in no case more than 400°F/hr (222°C/h).
(5) Above 800°F (425°C), cooling shall be done in a
closed furnace or cooling chamber at a rate not greater
than 500°F/hr (280°C/h) divided by the maximum metal
thickness of the shell or head plate in inches, but in no case
more than 500°F/hr (280°C/h). From 800°F (425°C) the
vessel may be cooled in still air.
The second part of this analysis is to have a PWHT procedure that identifies which locations will be heated and thermocouple placements. Note, the entire weld and surrounding base material (the heat affected zone) must be subjected to PWHT time at temperature requirements mentioned above. Verification of PWHT time and temperature will be based on a chart recorder that should be used as part of a PWHT procedure.
Portable hardness testing is also specified by clients, as your mentioned, to ensure PWHT has softened the weld and surrounding base metal heat affected zone.
The above information should get you started.
thanks for your feedback
the PWHT method already proceed as per UCS-56. but for the minimum holding time shall min. 60 minutes due to client specification.
however, your explanation is technical.
would you give me reference for calculate thermal analysis.
Go back and request more information from your client regarding thermal analysis. Is it possible possible your client is requesting a thermal analysis as part of the operational design of the pressure vessel? This relates to thermal ratcheting, and calculations can be found in several technical papers or a pressure vessel design handbook;
http://proceedings.asmedigitalcollection.asme.org/...
or
https://books.google.com/books?id=LRWCAAAAQBAJ&...
