Venmar CES Custom AHU Quality Issues?
We have specified an Eng-Air or Haakon custom AHU for an industrial project, but the contractor submitted a Venmar EnergyPack as an alternate. I'm unfamiliar with this manufacturer. Is it a recognized manufacturer and is it an equal to Eng-Air or Haakon? Any quality issues or concerns?
Thanks.
Thanks.
RE: Venmar CES Custom AHU Quality Issues?
i assume when you specified the eng-air you had specific qualities in mind? i guess go back to the reason to specify those brands int he first place and compare if the substitute is equal.
also depends on if the contract allows substitutes or if the contractor has to give you credit.
Unfortunately, the shop is not located within driving distance, so a visit isn't going to be easy.
Ask the contractor to ask Venmar for references to similar local installations by other contractors.
Follow-up on the references. Talk to the building engineer, talk to the maintenance guy.
Venmar doesn't show that they have much industrial process experience. Not clear if your application is comfort or process related.
