Relief Valve Capacity
We are being asked to change out all schedule 80 pipe nipples to Double X nipples. The ID of the nipples will be substantially smaller. If the nipple is on the inlet side of the relief, will it affect the capacity of the relief?
RE: Relief Valve Capacity
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
Good luck,
Latexman
Good luck,
Latexman
