NX 8.5 & 9 Hole Table Question
Any particular reason the highlighted areas in the hole table picture attached aren't condensed into one? Seems redundant to have the same callout in the table for multiple holes.(and it takes up space) I've played around with the hole table settings with no luck in correcting.
I know I can manually edit each row of the table to remove the excess callouts, but this is redundant and time consuming.
I do like the 'on the fly' changes made to the hole table in NX 9 though.
Thanks in advance!
Joe
PS. This happens in both NX 8.5 and 9
