Concrete Edge Breakout Strength for Pier Anchor Bolts
I am checking the concrete edge breakout strength of some anchor bolts for an exterior girder in a pier cap. The bridge is in Seismic Zone 1, so the only shear forces are due to the seismic forces. Of course the edge breakout strength fails miserably. Increasing the edge distance and cap depth helps some, but not nearly enough. The only other option is to add anchor reinforcing. This got me to thinking if I should even worry about the concrete strength, since the top reinforcing bars will be #9 bars with 180 degree hooks on the end. This seems to be similar to what is shown in Fig. RD.6.2.9(b) of Appendix D of ACI 318-08. However, the commentary for section D6.2.9 says that anchor reinforcing larger than #6 is not recommended. I am curious as to what others have done in this situation. Thanks.
RE: Concrete Edge Breakout Strength for Pier Anchor Bolts
