comparaison between analytical methods
Hello
So i was discussing with an expert on slope stability, and he stated that he uses bishop methods all the time .
When i argued that using it on transnational slides is not a good idea , he then answered that it can be viewed as a cercular failure with an infinite or very big radius .
What are your comments about this ?
RE: comparaison between analytical methods
There are slight improvements that can be made by applying one hand method or another to a given problem (based on soil type, geometry).. As I recall from some papers I read during my research, Janbu might be the most "accurate" of the hand or spreadsheet applicable solutions.
That said, for practical design purposes, this is largely irrelevant -- the factor of safety you'll need to apply will cover the slight variation. The counter case would be if you need to predict a failure point (rather than just determining a safe non-failure solution). In that case, you'd want to try to pick the method best suited to your site.
I also tend towards Bishop's method -- reasonable results, and simple to implement.
If you are only analizing homogenous slopes, then yes you could use Bishops method with a very large radius to get close to the results from a wedge type failure. However, if you are working in most real world situations where the soils are no homogenous, then you need a method that can handle different shaped failure surfaces.
I use Spencer's method. This is the method recommended by the USACE and is supported by many current slope stability software packages.
Mike Lambert
thank you all
Hi
Its depend on the type of slope you r analyzing. Let me know type of slope and conditions please.
Meantime see following paper if you fin it interest.
https://www.academia.edu/9805623/A_new_geotechnica....
Thanks.
Rasika or it Razika ^^
As i stated its just a general question , just an argument with an old man who believe that Bishop's method can be applied in every single case. I wasn't trying to look intelligent or something but i tested him with a delicate question : When mudflow or earthflow is initiated what kind of method should we be using ? and he stuttered for the answer was fluid mechanics :D
Thanks for the document
