Importing ADAMS variables to MATLAB/ Co-simulation
Is it possible to import ADAMS variable to MATLAB aka co-simulating both for data exchange ? I have a program in MATLAB which makes use of some simulations results of ADAMS like contact force and positions.
RE: Importing ADAMS variables to MATLAB/ Co-simulation
Actually, either way the answer is yes. I vaguely remember an ADMAMS/Control tutorial on that subject, if not your MSC support people will be able to help.
It is fairly trivial to build and run an ADAMS sim from Matlab, and then interrogate the results to build a new model.
Cheers
Greg Locock
For now I need to do it only one way i.e from ADAMS to MATLAB. I find it very inconvenient to import ADAMS results to a excel sheet and then import this excel sheet to MATLAB everytime. Regarding ADAMS/CONTROL, I even read about it, but its not the thing actually I'm lloking for. I just need an easier way to directly feed some variable values from ADAMS to MATLAB directly.
For example, I use chassis, it writes req files, which are actually cdf files, for which a function is available in matlab to read them in.
Cheers
Greg Locock
