Customization made in one session is not available in the next
I am adding new keyboard shortcuts for commands using the customize option available and also tried new shortcut icons where i am able to use everything in that session, once when i close everything and reopen the application everything is gone something like reset-ted... what should i do to retain the changes which i made...?
RE: Customization made in one session is not available in the next
If you're running NX 8.5 or older you will find your 'user.mtx' file at...
C:\Users\<user name>\AppData\Local\Unigrphics Solutions\<version of NX being run>
If you're running NX 9.0 or newer version of NX it will be located at...
C:\Users\<user name>\AppData\Local\Siemens\<version of NX being run>
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
There is a Preferences - USer interface - Layout- save layout at exit,
Which if ON, saves the "appearance" when exiting.
( It should not affect shortcuts, but still valid to check.)
Tomas
However, we have still experienced this problem to some degree in the past. If we set up our toolbars in customization, and close out of NX by simply clicking the red "x" at the top right, sometimes it does not remember the settings. We have found that if you save your work, close all parts, the actually go to File Exit once, it seems to always remember the settings. I never understood why it would make a difference and it may just be a glitch we had once and got used to doing it that way, but it might be worth a try if nothing else is working.
