Extrude on a cylindrical surface
Hey, I'm having some issues with some geometry I'm trying to make in Creo Parametric 2.0 and was wondering if some one could help me.
I have cylinder, and on this cylinder I want to cut out a shape around the cylinder. So it's kinda like I want to extrude in curved plane around the cylinder if you get what i mean? My question is, is this possible and how?
So far i've sketched with spline tool on regular plane and the used pattern tool, the problem is that I don't get the smooth transitions between the patterned features and I get edges on the shape.
Help would be appreciated. :)
RE: Extrude on a cylindrical surface
Draw your path on the cylinder, then the cross section at one end.
Ben Loosli
