View Names at Top of Views
Hi Friends,
I would like to place the view names of all views at the top of corresponding views using catvba. Kindly give me a hint for it and not the entire macro.
Harry
Harry
RE: View Names at Top of Views
You can play with the code bellow
CODE --> CATScript
Sub CatMain() Dim MyDoc As Document Set MyDoc = CATIA.ActiveDocument Dim MyDrawingDoc 'As DrawingDocument Set MyDrawingDoc = MyDoc Dim MySelection 'As Selection Set MySelection = MyDrawingDoc.Selection Dim Status As String Dim vFilter(0) vFilter(0) = "DrawingView" MySelection.Clear Status = MySelection.SelectElement2(vFilter, "Select Drawing View", True) Dim MyDrawingView As DrawingView Set MyDrawingView = MySelection.Item(1).Value MyDrawingView.Activate Dim MyDrawingSheet As DrawingSheet Set MyDrawingSheet = MyDrawingView.Parent Dim TextLocation(1) Status = MyDrawingDoc.Indicate2D("Indicate Text Location", TextLocation) Dim MyText As DrawingText Set MyText = MyDrawingView.Texts.Add(vbCrLf + "Scale", TextLocation(0), TextLocation(1)) Dim ParameterName As String ParameterName = "Drawing\" + MyDrawingSheet.Name + "\" + MyDrawingView.Name + "\Name" MsgBox ParameterName Call MyDrawingView.InsertViewScale(1 + Len(MyText.Text), MyText) Call MyText.InsertVariable(1, 0, MyDrawingDoc.Parameters.GetItem(ParameterName)) End SubRegards
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
I would put the view name text in noshow and check the frame size, then bring the view name text in show and position it according to frame size.
