Journal Moving Component Csys to Csys
I am attempting to move a component from a csys I created on its solid body to the ABS csys to try and keep it simple(if I can do this then will I simply translate the component later). The problem is rotating the component correctly. The solid body is not consistent with the component csys. I have both csys' created and have tried numerous code samples, as well as trying to combine some of those and using combinations of the group. Any help is greatly appreciated as I have ran out of ideas to try.
DHuskic
Data Prep Nx 7.5 & Nx 8.5
Kettering University Class of '17
RE: Journal Moving Component Csys to Csys
I'd say "UF_ASSEM_reposition_part_occurrence" is a good start to investigate...
I've used this thread[CompRot], to learn about component rotations. Then, using Gtac examples, perform transform operations to get the component csys back on top of the absolute csys. I was to use the same algorithms for this, but I need to figure out how to feed the MoveFromCsys information into one of those examples.
DHuskic
With best regards
Michael
Wikipedia has some decent articles for definitions, two are listed below:
http://en.wikipedia.org/wiki/Rotation_matrix
http://en.wikipedia.org/wiki/Transformation_matrix
www.nxjournaling.com
CODE --> VB
'Attempt to use mtx4Transform Dim translation(2) As Double TheUfSession.Mtx4.AskTranslation(mtx4Transform, translation) Dim rotation(8) As Double TheUfSession.Mtx4.AskRotation(mtx4Transform, rotation) TheUfSession.Mtx3.Transpose(rotation, rotation)RepositionIntstance
DragByTransform
Thank you for all your help.
DHuskic
CODE
'NXJournaling.com 'January 5, 2015 'Move a component from Csys to Csys 'Journal will prompt user to select a "from" csys and a "to" csys; the "from" csys should belong to the 'component that you want to move. Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim theUfSession As UFSession = UFSession.GetUFSession() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "reposition component" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) Dim fromCsys As CoordinateSystem Dim toCsys As CoordinateSystem If SelectCsys("Select 'From' coordinate system", fromCsys) = Selection.Response.Cancel Then Return End If If SelectCsys("Select 'To' coordinate system", toCsys) = Selection.Response.Cancel Then Return End If 'calculate Csys to Csys transformation matrix Dim fromOrigin() As Double = {fromCsys.Origin.X, fromCsys.Origin.Y, fromCsys.Origin.Z} Dim fromXAxis() As Double = {fromCsys.Orientation.Element.Xx, fromCsys.Orientation.Element.Xy, fromCsys.Orientation.Element.Xz} Dim fromYAxis() As Double = {fromCsys.Orientation.Element.Yx, fromCsys.Orientation.Element.Yy, fromCsys.Orientation.Element.Yz} Dim toOrigin() As Double = {toCsys.Origin.X, toCsys.Origin.Y, toCsys.Origin.Z} Dim toXAxis() As Double = {toCsys.Orientation.Element.Xx, toCsys.Orientation.Element.Xy, toCsys.Orientation.Element.Xz} Dim toYAxis() As Double = {toCsys.Orientation.Element.Yx, toCsys.Orientation.Element.Yy, toCsys.Orientation.Element.Yz} Dim mtx4Transform(15) As Double theUfSession.Mtx4.CsysToCsys(fromOrigin, fromXAxis, fromYAxis, toOrigin, toXAxis, toYAxis, mtx4Transform) 'extract the rotation matrix and the tranlsation vector Dim rotMatrix(8) As Double theUfSession.Mtx4.AskRotation(mtx4Transform, rotMatrix) Dim transVec(2) As Double theUfSession.Mtx4.AskTranslation(mtx4Transform, transVec) 'convert array of doubles to vector 3d Dim translateVector As Vector3d = New Vector3d(transVec(0), transVec(1), transVec(2)) 'convert array of doubles to Matrix3x3 Dim rotationMatrix As Matrix3x3 = convertToMatrix3x3(rotMatrix) 'determine component to move based on the chosen "from" csys Dim comp As Assemblies.Component = fromCsys.OwningComponent Dim componentPositioner1 As Positioning.ComponentPositioner = theSession.Parts.Work.ComponentAssembly.Positioner Dim network1 As Positioning.Network network1 = componentPositioner1.EstablishNetwork() Dim componentNetwork1 As Positioning.ComponentNetwork = CType(network1, Positioning.ComponentNetwork) Dim markId2 As Session.UndoMarkId = Nothing If comp IsNot Nothing Then markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Move Component") Dim movableObjects() As NXObject = {comp} componentNetwork1.SetMovingGroup(movableObjects) 'reposition component from the rotation matrix and translation vector componentNetwork1.DragByTransform(translateVector, rotationMatrix) componentNetwork1.Solve() End If theSession.UpdateManager.AddToDeleteList(componentNetwork1) theSession.UpdateManager.DoUpdate(markId2) lw.Close() End Sub Function SelectCsys(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select a Coordinate system" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_coordinate_system_type .Subtype = UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selobj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Function convertToMatrix3x3(ByVal mtx As Double()) As Matrix3x3 Dim mx As Matrix3x3 With mx .Xx = mtx(0) .Xy = mtx(1) .Xz = mtx(2) .Yx = mtx(3) .Yy = mtx(4) .Yz = mtx(5) .Zx = mtx(6) .Zy = mtx(7) .Zz = mtx(8) End With Return mx End Function End Modulewww.nxjournaling.com
DHuskic
Whoops! I was so focused on getting the component to move correctly that I forgot to "apply" the move. The corrected code is below:
CODE
'NXJournaling.com 'January 5, 2015 'Move a component from Csys to Csys 'Journal will prompt user to select a "from" csys and a "to" csys; the "from" csys should belong to the 'component that you want to move. Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim theUfSession As UFSession = UFSession.GetUFSession() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "reposition component" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) Dim fromCsys As CoordinateSystem Dim toCsys As CoordinateSystem If SelectCsys("Select 'From' coordinate system", fromCsys) = Selection.Response.Cancel Then Return End If If SelectCsys("Select 'To' coordinate system", toCsys) = Selection.Response.Cancel Then Return End If 'calculate Csys to Csys transformation matrix Dim fromOrigin() As Double = {fromCsys.Origin.X, fromCsys.Origin.Y, fromCsys.Origin.Z} Dim fromXAxis() As Double = {fromCsys.Orientation.Element.Xx, fromCsys.Orientation.Element.Xy, fromCsys.Orientation.Element.Xz} Dim fromYAxis() As Double = {fromCsys.Orientation.Element.Yx, fromCsys.Orientation.Element.Yy, fromCsys.Orientation.Element.Yz} Dim toOrigin() As Double = {toCsys.Origin.X, toCsys.Origin.Y, toCsys.Origin.Z} Dim toXAxis() As Double = {toCsys.Orientation.Element.Xx, toCsys.Orientation.Element.Xy, toCsys.Orientation.Element.Xz} Dim toYAxis() As Double = {toCsys.Orientation.Element.Yx, toCsys.Orientation.Element.Yy, toCsys.Orientation.Element.Yz} Dim mtx4Transform(15) As Double theUfSession.Mtx4.CsysToCsys(fromOrigin, fromXAxis, fromYAxis, toOrigin, toXAxis, toYAxis, mtx4Transform) 'extract the rotation matrix and the tranlsation vector Dim rotMatrix(8) As Double theUfSession.Mtx4.AskRotation(mtx4Transform, rotMatrix) Dim transVec(2) As Double theUfSession.Mtx4.AskTranslation(mtx4Transform, transVec) 'convert array of doubles to vector 3d Dim translateVector As Vector3d = New Vector3d(transVec(0), transVec(1), transVec(2)) 'convert array of doubles to Matrix3x3 Dim rotationMatrix As Matrix3x3 = convertToMatrix3x3(rotMatrix) 'determine component to move based on the chosen "from" csys Dim comp As Assemblies.Component = fromCsys.OwningComponent Dim componentPositioner1 As Positioning.ComponentPositioner = theSession.Parts.Work.ComponentAssembly.Positioner Dim network1 As Positioning.Network network1 = componentPositioner1.EstablishNetwork() Dim componentNetwork1 As Positioning.ComponentNetwork = CType(network1, Positioning.ComponentNetwork) Dim markId2 As Session.UndoMarkId = Nothing If comp IsNot Nothing Then markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Move Component") Dim movableObjects() As NXObject = {comp} componentNetwork1.SetMovingGroup(movableObjects) componentNetwork1.BeginDrag() 'reposition component from the rotation matrix and translation vector componentNetwork1.DragByTransform(translateVector, rotationMatrix) componentNetwork1.EndDrag() componentNetwork1.ResetDisplay() componentNetwork1.ApplyToModel() componentNetwork1.Solve() End If theSession.UpdateManager.AddToDeleteList(componentNetwork1) theSession.UpdateManager.DoUpdate(markId2) lw.Close() End Sub Function SelectCsys(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select a Coordinate system" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_coordinate_system_type .Subtype = UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selobj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Function convertToMatrix3x3(ByVal mtx As Double()) As Matrix3x3 Dim mx As Matrix3x3 With mx .Xx = mtx(0) .Xy = mtx(1) .Xz = mtx(2) .Yx = mtx(3) .Yy = mtx(4) .Yz = mtx(5) .Zx = mtx(6) .Zy = mtx(7) .Zz = mtx(8) End With Return mx End Function End ModulemarkId1 and markId2 are undo marks. markId1 exists only so that the user can "undo" the results of the journal; it is for convenience and can be omitted if desired. The DoUpdate method requires an undo mark as an argument; if any errors occur during the update, NX will roll back to the given undo mark and throw an exception. In this short example journal, markId1 could have been used instead of making a new mark to use. A longer, "real world" program might have many steps which you would not want to undo should an update error occur. In this case, I'd suggest creating an undo mark for each significant step so as to not roll back all the way to the start of the journal.
