CATIA VB Programming, Get the name and place it as the text file name.
I have learned how to get the name of the part file and place it as the name of the text file that I want to write to, but my problems are:
1. I can only get it to make the new text file write to drive C:
2. And I cannot internally populate the points at the same time using stream writer, because I have to make it get the file name from CATIA.
How do I accomplish this?
My Code:
Sub CATMain()
'==================Call Variables=====================================
Dim ObjFso
Dim SourceLocation
Dim DestinationLocation
Dim SourceFileName
Dim DestinationFileName
SourceLocation = "C:TestFolder1"
DestinationLocation = "C:TestFolder2"
SourceFileName = "Source File.txt"
DestinationFileName = "Destination File.txt"
Dim aToExport(5000, 3) As Variant
Dim iNumberOfPoint As Integer
Dim sTime As String
Dim sName As String
Dim FileObj
'=================CATIA Declarations===================================
On Error Resume Next
Set PartDocument1 = CATIA.ActiveDocument
Set part1 = PartDocument1.Part
Set hybridShapeFactory1 = part1.HybridShapeFactory
Set objNetwork = CreateObject("Wscript.Network")
Set hb1 = CATIA.ActiveDocument.Part.InWorkObject
Set hsf = CATIA.ActiveDocument.Part.HybridShapeFactory
Set prt = CATIA.ActiveDocument.Part
Set sel = CATIA.ActiveDocument.Selection
Set SPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Set PlaneZX = CATIA.ActiveDocument.Part.OriginElements.PlaneZX
' Reset the Selection
Set sSEL = CATIA.ActiveDocument.Selection
sSEL.Clear
'====================Create A Text File With CATIA Part Name===============
sTime = Replace(Time, ":", "-")
sName = "C:\" & Left(CATIA.ActiveDocument.Name, Len(CATIA.ActiveDocument.Name) - 8) & "-" & sTime & ".txt" '<----Creates A file with the Active Part Name in CATIA
Open sName For Output As #1 ' open file for writting
Set FileSys = CATIA.FileSystem
'=================Select The Objects In CATIA And Write To File============
'FileObj = FileSys.CreateFile("C:\pointsout.txt"=
Set TextsTr = FileObj.OpenAsTextStream("ForWriting")
Dim selection1
Set selection1 = PartDocument1.Selection
selection1.Add part1.FindObjectByName("RibPath")
selection1.Search "CATPrtSearch.Point,sel"
Dim Coord(2) '<-----Other Code
For I = 1 To selection1.Count '<-----Count Each Point Other Code
Dim CurrWorkbench '<----WorkBench Variable
Set CurrWorkbench = PartDocument1.GetWorkbench("SPAWorkbench") '<----Get Current WorkBench in CATIA
Dim Measure '<-----Measure Variable
Set Measure = CurrWorkbench.GetMeasurable(selection1.Item(I).Reference) '<----Get Current Measurement
Measure.GetPoint Coord '<------Getting the Points Using Measure Method
TextsTr.Write (Coord(0) / 25.4 & ", " & Coord(1) / 25.4 & ", " & Coord(2) / 25.4 & vbCrLf) '<-----Writes the Coordinates in inches
Set FileObj = FileSys.CreateFile("C:\pointsout.txt", True) '<----This does work in writing the points to a text file, but doesn't have the Part Name instead it makes the text file "pointsout.txt
Next
part1.Update
Close
MsgBox "Check the file : " & sName, vbInformation ' information about job done
'==============Create A Directory Folder If It Doesn't Exist==============
strFolderPath = FolderPath & "\" & FolderName
If Dir(strFolderPath, vbDirectory) = "" Then
Set FileObj = FileSys.CreateFolder("C:\Tube Production")
Else
End If
'==============Copy A File To The File To Folder "Tube Production=========
Set FileSys = My.Computer.FileSystem
My.Computer.FileSystem.RenameFile "C:\Tube Production\pointsout.txt", "C:\Tube Production\" & Left(CATIA.ActiveDocument.Name, Len(CATIA.ActiveDocument.Name) - 8) & ".txt" <----Doesn't work, but I tried to make it change the name to CATIA Active Document Part Name
End Sub
My Code:
Sub CATMain()
Dim ObjFso
Dim SourceLocation
Dim SourceFileName
Dim sTime As String
Dim sName As String
Dim FileObj
sSEL.Clear
Dim selection1
Next
part1.Update
Close
Else
End If
End Sub
RE: CATIA VB Programming, Get the name and place it as the text file name.
i believe the answer to your question is this.
CODE
Sub CATMain() '==================Call Variables===================================== Dim ObjFso Dim SourceLocation Dim DestinationLocation Dim SourceFileName Dim DestinationFileName SourceLocation = "C:TestFolder1" DestinationLocation = "C:TestFolder2" SourceFileName = "Source File.txt" DestinationFileName = "Destination File.txt" Dim aToExport(5000, 3) As Variant Dim iNumberOfPoint As Integer Dim sTime As String Dim sPath As String '<---------------------------------------------------------------------------------------------------added Dim sName As String Dim FileObj '=================CATIA Declarations=================================== On Error Resume Next Set PartDocument1 = CATIA.ActiveDocument Set part1 = PartDocument1.Part Set hybridShapeFactory1 = part1.HybridShapeFactory Set objNetwork = CreateObject("Wscript.Network") Set hb1 = CATIA.ActiveDocument.Part.InWorkObject Set hsf = CATIA.ActiveDocument.Part.HybridShapeFactory Set prt = CATIA.ActiveDocument.Part Set sel = CATIA.ActiveDocument.Selection Set SPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") Set PlaneZX = CATIA.ActiveDocument.Part.OriginElements.PlaneZX ' Reset the Selection Set sSEL = CATIA.ActiveDocument.Selection sSEL.Clear '====================Create A Text File With CATIA Part Name=============== sTime = Replace(Time, ":", "-") sPath = Left(CATIA.ActiveDocument.Path, len(CATIA.ActiveDocument.Path)) '<------------------------------------------------------------------added sName = sPath & Left(CATIA.ActiveDocument.Name, Len(CATIA.ActiveDocument.Name) - 8) & "-" & sTime & ".txt" '<----Creates A file with the Active Part Name in CATIA <-- modified Open sName For Output As #1 ' open file for writting Set FileSys = CATIA.FileSystem '=================Select The Objects In CATIA And Write To File============ 'FileObj = FileSys.CreateFile("C:\pointsout.txt"= Set TextsTr = FileObj.OpenAsTextStream("ForWriting") Dim selection1 Set selection1 = PartDocument1.Selection selection1.Add part1.FindObjectByName("RibPath") selection1.Search "CATPrtSearch.Point,sel" Dim Coord(2) '<-----Other Code For I = 1 To selection1.Count '<-----Count Each Point Other Code Dim CurrWorkbench '<----WorkBench Variable Set CurrWorkbench = PartDocument1.GetWorkbench("SPAWorkbench") '<----Get Current WorkBench in CATIA Dim Measure '<-----Measure Variable Set Measure = CurrWorkbench.GetMeasurable(selection1.Item(I).Reference) '<----Get Current Measurement Measure.GetPoint Coord '<------Getting the Points Using Measure Method TextsTr.Write (Coord(0) / 25.4 & ", " & Coord(1) / 25.4 & ", " & Coord(2) / 25.4 & vbCrLf) '<-----Writes the Coordinates in inches Set FileObj = FileSys.CreateFile("C:\pointsout.txt", True) '<----This does work in writing the points to a text file, but doesn't have the Part Name instead it makes the text file "pointsout.txt Next part1.Update Close MsgBox "Check the file : " & sName, vbInformation ' information about job done '==============Create A Directory Folder If It Doesn't Exist============== strFolderPath = FolderPath & "\" & FolderName If Dir(strFolderPath, vbDirectory) = "" Then Set FileObj = FileSys.CreateFolder("C:\Tube Production") Else Set FileObj = FileSys.CreateFolder("C:\Tube Production") End If '==============Copy A File To The File To Folder "Tube Production"========= Set FileSys = My.Computer.FileSystem My.Computer.FileSystem.RenameFile "C:\Tube Production\pointsout.txt", "C:\Tube Production\" & Left(CATIA.ActiveDocument.Name, Len(CATIA.ActiveDocument.Name) - 8) & ".txt" <----Doesn't work, but I tried to make it change the name to CATIA Active Document Part Name End Sub
