Wall Collapse at Morton Salt
3
RE: Wall Collapse at Morton Salt
I'm from and still spend considerable time in Chicago. You can see that big Morton Salt Roof Sign, "When It Rains It Pours" from the Kennedy Expressway.
I get the feeling that the occupants of an old factory like that get kind of comfortable and push the load to the limit and beyond.
"When the Wall Fails it Pours" may have to be the new sign.
Salt water intrusion...???
Mike McCann, PE, SE (WA)
They're going to have to throw a lot of salt over their shoulders to make up for this one.
Maine Professional and Structural Engineer.
(Just passed the 16-hour SE exam, woohoo!)
Sounds like the wall was not worth it's salt.
My past experience is that you cannot *know* that no one was hurt until all the material is cleaned up.
We've found people who weren't meant to be where they were found... They still died there. On on particular job in Fiji the employer assured us no one was hurt. Two found burried during the removal of materials.
The US may not be Fiji, but nor can you *know* what is under that salt. Then again it may already have been cleaned up, but I doubt it.
The Morton people are probably going to be peppered with a lot of questions.
Show me the CARFAX
Is "buried under a pile of salt" one of the categories on a CARFAX?
DaveAtkins
[quote=bridgebuster]The Morton people are probably going to be peppered with a lot of questions. [/quote]
I'm guessing they were reposed before this happened. But they'll now have to answer the questions from a different angle.
It appears to me that the building was never intended to have salt piled above the concrete wall and clearly it was.
From the comments below the article by one Jamie Wilson, "Headline fail. Should have been "Lot Turned Into Pillar of Salt.""
I'd give her a star if I could.2thumbsup
Since that salt will probably be condemned for public consumption, Chicago's highway and street department will be glad to use it to salt their
their streets and sidewalks eventho. the grains of salt are not in the right size.
It may not work for dry salting, but it will still work for anti-icing brine.
chicopee…the article stated that the salt in question is road salt, not table salt.
I noticed from the photos that this happened on a clear day. Morton's new slogan should be, "Even when it doesn't rain, it pours."
--Winston S. Churchill
