Fillet radius of W8X35 Wide Flange Beam
Does anyone know what the real inside corner fillet radius is for a W8X35 wide flange beam?
I need to put some holes in the beam for bolts, washers and nuts, but do not want the washers to touch the radius.
RE: Fillet radius of W8X35 Wide Flange Beam
So this would make the radius of the weld at 1/2" with the flange thickness being 1/2".
Mike McCann, PE, SE (WA)
Look in an older AISC Steel Design Manual, in the front, for W Shapes Dimensions for Detailing. The R you are looking for is about .4", for a W8x35, a W8 which is 8x8. Look at the (T, k, k1, g1, c & g) dimensions; they are 6&1/8", 1", 9/16", 2&1/4", 3/16", and 5&1/2" respectively. They might vary a little from mill to mill or with the conditions of their rolling mill at the time of rolling. They are dimensions in the region of the radius and the web/flg. area, and std. gage dimensions for bolting holes.
